mxman29
PR Member
Only has aprox 40hrs on this 1 sided Ohlins system by Coppersmith. Was on a 2018 Husky FC450 Set for 180Lb B rider. It allows you to run 1 spring(.45) on the 1 side, and half the amount of air pressure on the other fork leg(75psi instead of 150psi). All at half the weight added back on with a double spring conversion. This was the best suspension set up ive ever had in last 30yrs. Coppersmith was praised on many magazines, and now sells this same exact system for $1400. Cash only, call or text(8one4)3two3-1four9seven
